Mad Farmer
- Location
- Northeast
Making slow progress on my Ferguson, I get one thing fixed then find another repair that needs fixing...
Latest one is had to replace manifold which required removing the gas tank. Tank started to leak after reinstalled.
Overall tank is in good shape and rust free inside and out except for a few spots exterior where paint had been scuffed. And it has a dent.
First question is inside the tank there seems to be some sort of baffle which is loose to move around. Was the baffle's purpose to deal with sloshing fuel? And is it loose due to damage?
The tank has a large dent in the bottom, in the area covering the valve cover. It seems to have been caused by someone pounding the bottom from the inside through the filler? How it happened or why I have no clue.
The leaks are tiny cracks on a portion of the dented area. I've cleaned these up and the metal is very sound, inside and out. Pictures are included.
Current plan is to make sure drained tank is free of fumes, flush it with an argon tank, and braze the cracks. I have gas welding equipment and I'm good at brazing thin sheet metal, have brazed on entire auto quarter panels seamlessly. I have no electric welders. Any thoughts on this?
This may just be a quick fix to get things up and running before the snow flies, paint over the repair. Other thoughts are to paint the whole tank while it is out and adjust the valves. Tractor lives outside so weather will determine the latter.
Pictures. Note cracks are pictured looking from different side of the tank from dent pictures. The cracks are over the valve cover area behind the center of the exhaust manifold.
Any ideas how/why dent got there? Tank is bulged outward from the inside, not dented from the outside.
![mvphoto112037.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto112037.jpg)
![mvphoto112038.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto112038.jpg)
![mvphoto112039.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto112039.jpg)
![mvphoto112040.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto112040.jpg)
![mvphoto112041.jpg](https://forumphotos.yesterdaystractors.com/photos/mvphoto112041.jpg)
