to-30 sleeve vertical height
daringaston
need 2raise sleeves up slighlty to get head gasket to seal down ,also have new o-rings on sleeves they leak and sleeves fit loose . know of any remedies for this problem?
(quoted from post at 15:02:13 01/17/10) need 2raise sleeves up slighlty to get head gasket to seal down ,also have new o-rings on sleeves they leak and sleeves fit loose . know of any remedies for this problem?
Per ron8 on "raising the sleeves".. but sleeves with new orings should fit tight.. Are you certain it is at the oring? or is there the possibility of cracks at the bottom... ( a common problem).. might also explain "loose fit"
i checked 4 cracks found one between #4&#3 no other cracks but all sleeves fit loose. I sprayed copper gasket product around openings,applied red rtv silicone on top and bottom edges of sleeves,then inserted them leaving slightly raised. do you think this will work?
Definitely not the best way to fix it, but worth a try I guess.. I suspect RTV will work for the bottom, but I would be concerned with interference at the top.. you didn't say how much the sleeves are raised.. should be just a few thousands.. but the RTV will probably compress and slide out of the way anyway as the head is torqued... and are your using a new head gasket each time?? I presume not.. but reusing it is not correct either...
will re-assemble and check 4 leaks again head gasket has been torqued down before but not used liners are up 4-5 thousandths will report later this week thank you for your help
update: tractor is running well ,I put a bottle of bars block seal (copper type) direct into inlet on head before putting on radiator hose.I have not noticed any leaks.
