my 1957 TO-35 sits in the barn 98% of the time and almost never gets rained on. The rubber boots over the shift levers are in excellent shape.
I have changed the hyd/trans fluid years ago, but just cannot remember when. it has been over 6-7 years. The tractor is not used that much, but runs and drive great, lift works fine.
I always use GL-1 oil in the hyd/trans sump.
so what say you guys, would you change the hyd/trans oil this spring?
I know the hyd/trans oil should be hot before its drained out and needs about 1 day to fully drain.
Thanks Fred,
Thanks Fred,
