TO-35 Tuneup Question
maxwell99
QUESTION:
When you are installing a new set of points in a Z134 gas engine, why is it or is it necessary to replace the condensor?
What exactly does the condensor do, does it get weak or is it go-nogo electrical device?
I just put points in my tractor, they were pitted, but did not replace the condensor, so I got one today, and will replace it, however, tractor is running great with old condensor.
They advise you to change the Condenser each time you change the points or if you get a spike or hole in the points. The Condensers do deteriorate over a period of time, some don't last very long at all. It stores the charge for the points to trigger....John
The function of the condenser is to stop the flow of current across the points instantly as the points start to open, store that current and release it intantly when the points close again. If you did not have a condenser the current would arc across the points on opening and burn them up. The biggest killer of condensers is moisture, they will last a long time on vehicles that are used a lot and a short time on infrequent use.
Re condensor, I had a JD 50 that suddenly failed to start just minutes after shutting down. Checked a bunch of stuff with no results. Final step was to change condensor, tractor started just like it always had.
