To20 counter weight
I am interested in making a counter weight that does not mount to the axle, mark hendershot posted a pic in the implements forum I liked but he does not have an email address I can find out more about the mounting. has anyone else got pictures of a non axle mounting counter weight that you might send me?
Thanks Robert
If you get any info about this counter balancer would you please consider sharing on the forum for all too share. I would also like to get and or make one myself. Thank You
The home made weights I've seen are attached to the three point.
THey are simply a conainer of the right size for the weight desired. a Rod the diameter of the attach pins is placed through through the conatiner and then it is filled with concrete. Once set you have your weight, easy on easy off.
Jeff
i had one for my to-30. it was half a 55 gal drum with a drawbar inserted through it then filled with concrete and an attachment for connecting a top link to the tractor set in palce on top.
Simplest is a three point scoop. Fill it with rocks. Remove or add rocks as you need to change the weight.
