Kevin Godshall
'53 TO30
12V Neg Ground
Been running tractor right along this year: plowing snow in winter, plowing garden in spring, running brush hog in summer.
During brush hogging, tractor seemed to be wanting in the power department, but I chalked it up to extra high, extra thick grass. Took half cuts and got the job finished without any thought to it.
Time to start pulling logs, but now tractor doesn't seem to want to run. Starts right off the bat, idles fine, but as soon as I put it into gear, we get into trouble. If I try to drive out the driveway in 2nd gear, it coughs and sputters and finally dies. When I took it downhill, it was surging and rough. Couldn't climb the back hill to the garage in 2nd gear, so I backed down to the bottom. Pulled the air intake off of the carb and restarted her. Idling rough now. Reattached the air intake and no difference. Tried pulling the choke out as she was struggling and she died.
After a few minutes of contemplation (mostly off color language), I restarted her and got her up the hill in 1st gear. (Not pretty, but she made it).
So........ here's what I did so far: First, removed the sediment bowl, and then replaced it because it was leaking and gunky. Flushed the gas tank and fuel line and re-connected it.
Second, disassembled the carb and fully cleaned it. Made sure float was right and main jet was clean. Reassembled and reinstalled, adjusting to specs in manual. (Main jet and idling air).
No success.
Third, pulled plugs and inspected. All looked good, not fouled or burnt. Re-gapped and reinstalled.
Fourth, pulled the valve cover and inspected the springs and rods. All looks good and seems to be working fine.
Fired it up and it idled fine. Wife came out celebrating the success. I backed it up about 100 ft and it wasn't horrible, (slight upcline), then I shifted into 2nd and it began choking. Made it back about 50 ft before she died.
Seems like when she is cold, she idles best. But as soon as I put her into gear, especially 2nd or higher, it's all over.
Exhaust looks clear (not overly black or white). All gas is new and clean. No backfiring.
I played a bit with the throttle rod and governor, but I'm now thinking (after reading some posts here), maybe I need to look at coil and distributor? Manual not helping me much on the 12V conversion, so I'm back to the experts for help.
Thanks.
12V Neg Ground
No success.
Thanks.
