TO35 need a new rim
I have a TO35 that has a rotted out rim. I dont trust my judgement on choosing the right rim. The tire that is on the rim reads:
Field & road
Tire - sup-r-lon 1-MBDL
BD-30974
14.9-24 on 13" rim
13-24
R-1 4 ply.
The rim in the photo is the good one.
Can anyone help with this please?
Aaron
Its a 24" x 13" wide rim having 6 loops. For a TO-35. That's what the tire would like. But according to my MF-135 parts book they used a 12" wide rim 24" in diameter. You can measure your rim width, even with the tire on it, just measure the outside width below the flare along side the bead and subtract about an eighth inch for two metal thicknesses.
It may be available from Gemplers, nnalert, Miller tire, and most places that carry parts for Massey and Ford tractors, including this company, yesterday's tractors. You might want to measure the distance between the loop bolt centers to be sure of the fit.
It should also be available from tractor salvage yards in quantity.
Gerald J.
I believe you have a 12" by 24" double bevel rim. Which means it has no loops to run bolts through. The clamps on the bolts hold the rim on. The clamps straddle the bevel part of the rim. I have this type rim on an F40 and have just replaced both rims. According to the guys at Mac Tractor in OK. the 6 loop rim will NOT bolt to the center disc. It comes close but will not work.
I can confirm the center will not bolt to a standard 6-loop rim.
I would like to find one of these original 13x24 rims in decent condition, if anyone has one.
