todays project
billonthefarm
Location
Farmington IL
Took this apart last week. Got the parts and got one the side started back together and should finish it all up today. Wasnt much wrong. The axle seal was starting to leak a little on the left so we took both sides apart and replaced bearings, axles shafts, sun gears and oil as preventive maintenance. With right at 5000hrs an ounce of prevention is a good program with the cost of a tractor to replace this one being so high.
bill
I have had many of them apart. Don't see 875's with 3pts around here. Have a 1150 in shop for the same work right now.
Now that there is a dirt moving beast.
How many horse is that thing?
I like the ton of weight up on that rear axle.
Gary
That's a big one, that folding chair kinda looks like it's being used for a jack stand. Alan will probably be trying that next. Jim
You will break a axle housing long before axle shaft trouble.Could of flipped the planatary gears to the other side been like new.Mark
