I would like to buy my son and I a welder. Neither he nor I have welding experience so ease of learning is a factor. Budget is $500 max. I can buy a like new Lincoln PRO MIG 180 or a Lincoln 225 AC/DC TOMBSTONE for $500. Specs for mig are;
Input Power208/230/1/60
Rated Output208: 130A/17V/30% 230: 130A/20V/30%
Input Current20A
Output Range30-180A
Solid Wire Size Range.025-.035 in.
Cored Wire Size Range.030-.045 in.
Wire Feed Speed Range50-500 ipm (1.3-12.7 m/min)
Dimensions,14"H X 10.15"W X 18.6"D (H x W x D)
Net Weight 66 Lbs
Gas regulator included. No tank nor spool gun with it. They rate it up to 1/2" with flux core which is ample for our use but I don't know if that's single pass. I find most of what I hire welded and fabercated to be between 1/16th and 3/8ths.
For steel,aside of tombstone'S capiable of much thicker and mig capiable of much thinner material is either welder remarkably better for begainers? How important do you find cleaner weld with gas shielding and capibility for aluminum (with optional spool gun)?
Thanks in advance and hopfully I supplied enough info to alow meaningful opinions.
Input Current20A
Output Range30-180A
Net Weight 66 Lbs
