Tractor Carburator
They didn't make a DLTX-13. That would be a bowl number. The carb number will be stamped on a flat spot an the carb body. It will be on the backside as it is mounted and towards the front of carb.
JD A"s from 1947 thru 1952;
Gasoline DLTX 71
All-Fuel DLTX 72
DLT 13 is the casting number of the bowl used on all DLTX carburetors except for early unstyled tractors and H"s.
mark-ia I found the numbers where you said they should be and I have a DLTX 71 for gas. it is the right carb for the tractor.Thanks for the help. MK
