Tractor hydrulic leak
Missouri Man
I have a Mahindra 2810 that is spraying hydrulic fluid under the hood when ever I look I cant see it spraying but it did spray all over the place
my guess is a split hose or loose conection I havent been able to locate either do any of you think y'all could give me an idea what to do?
I am not a mechanic
i dont know anything about mahindra tractors but if youre going to look for it, do not feel for it with your hand. use cardboard and safety glasses if you get injected with pressurized oil go to the doctor immediately and get it surgically removed. you will get gangrene if you dont. with that said more than likely it is a blown gasket, o-ring, bad hose. just look for it carefully
Check your hydralic fluid. See if it's low. If not you know to check other places. If low put some in it and start it up and check for leaks then. Might be so low now that it is not showing and you might burn something up like a pump.
If you have power steering on it. Check that to!
Take the hood off. Wash everything squeaky clean. When dry spray with aerosol flour. It will show seeps. If nothing seeps, crank it but don't let it start. If nothing shows, run it a second or two. By then something should show in the flour.
Gerald J.
