Tractor pictures
grandpa Love
Got a load of gravel delivered today. I got a shovel and rake to smooth it up... My wife got the tractor to dump it in the lean to. It's gravel from the local marble quarry. Looks like it snowed! Couldn't believe the price, $180. Big load!
(quoted from post at 09:58:34 02/15/22) You would be hard pressed to find a tri axle that would deliever to homes around here.
hy does it matter if home or business as long as there is room to maneuver?
(quoted from post at 06:58:34 02/15/22) You would be hard pressed to find a tri axle that would deliever to homes around here.
Leroy I drove tri-axle part time for 15 years. 90% of the time the material went to major construction sites, but occasionally it was to a job at a home. If someone needed a load and it was someone that the contractor knew, they would deliver it.
(quoted from post at 08:32:05 02/15/22)
JMOR, generally there is no less room at a home than on a major construction site. Most construction laborers are handicapped so they all need to park within 25 feet of the structure under construction. So it gets very tight, just inches on each side.
For Grandpa Love I put my little Massey to work also. This is the maximum wt and height it will handle but hay not bad for the little girl
You did good. 12 ton bobtail of crushed, old concrete around here got $375 several years ago. No telling the price today.
A lot more tandem axle trucks than 3 axle trucks and the 3 axle are all tied up with full time jobs for the truck so no chance for a home owner to get one to do the hauling. Cannot give up a commercial daily load the a one time home owner.
We we built our big corn bin in Talladega, we used marble waste from the quarry in Sylacauga to fill the bin base as it was the cheapest material the met the specifications for compaction. It took quite a few yards to fill a 74 foot diameter foundation.
(quoted from post at 07:35:55 02/16/22) A lot more tandem axle trucks than 3 axle trucks and the 3 axle are all tied up with full time jobs for the truck so no chance for a home owner to get one to do the hauling. Cannot give up a commercial daily load the a one time home owner.
Leroy, there are a lot more tri-axle trucks than tandems. 90% of the time the material I hauled went to major construction sites, but occasionally it was to a job at a home. If someone needed a load and it was someone that the contractor knew, they would send me to deliver it. Also even though the company that I worked for did mainly large commercial building site work, we would do two or three homesites a year.
