tractor pull left or right
Anonymous-0
Have had a problem for several years,my pullin tractor always goes left or right as soon as the front wheels lift . I have decided its ovious that it acts like diff lock, is spider gears not running free
No ,the drawbar is in the center,I have tried several sets of tires, raised and lower tire pressure, still the same
Check and make sure the rims are matched. Mine are a litle off which makes one ire just a little taller than the other. Also make sure the hubs are the same distance from the tractor. It does"t take much to throw the center off. Hitch needs to be in the center of the tires as well.
Unless your having trouble with one wheel pulling and the other not then your spider gears are probably not the problem. Now if your digging in one one side and not the other then I would check them
I have tryed several different sets of tires ,mounted, so I know its not tires, wheel, rims ,or distances. If you ever driven a regular farm tractor with factor diff lock, that what it acts like , wants it gets a mind of its own ,and changes directions,steering, brakes ,etc, you cannot change it back to go straight
If it's consistantly one side, it could be a bad bearing or a brake dragging. If it's either side it might be in the spider gears. Have you jacked it up and spun the tires?
Just like drag racing, space the rear end as narrow as possible. the wide stance gives the tire more leverage to push the front to one side or other,,try it
You said you have changed air pressure, but have you staggered the air. Drop one side by a .5 pound to a pound and see if it helps. My second MM had to have 1.5 lb in the left more than the right to go straight.
you have NO IDEA what you are talking about! Build something other than the stock stuff you put together and test it ve real horsepower tractors! I laugh every time you post something Mr DWL HAHAHAHHAHA
Yes this is what I am thinking,these needle brg, do they replace the thrust washers on the axle gears.or go else where
You have no idea who you are talking to. My nane is Ray Kiefer from missouri and I am going to pat myself on the back , I sure dont know everything ,but I am a little bit better than the average mechanic 573-547-1965. cell 573-517-3739
