Tractor Recommendation
Samaritan
I need some ideas and solid opinions. I have 160 acres and I am looking for a good used tractor that is capable of working this plot. I plant dryland crops (wheat, etc) and need some recommendations as to a good, solid, used tractor that would fit my needs.
Give me some ideas and, as always, thanks....
First I'd say you need to say what your budget is, and what kind of implements do you have if any. There's a lot of guys here that can give you good info, based on you giving THEM good info. Also, what kind of dealers do you have close by for parts and service? BTW, you might look at buying a pair of older tractors for a backup plan and to save time changing implements.
Again, just looking to pick everyone's brain and get some opinions. You know the size of the property and that I'm doing dryland farming...soooo what's your opinion.
I imagine that my horsepower requirement will be around 100 give or take. How about some ideas on your favorite used tractors in that general category....
Well a couple of old IH 's would work are cheaper than Deere and very durable. I would go with an 856,1256 or get into the 66 series 1066 or 1466 any one of these will do what you want. The 06 series will work also, 806,1206 the 1206 is getting to be quite a collectors item though, so the price is getting kind of high. These are tractors in the 90-140 horse range. these will all have PTO,dual hyd.The newer ones will have 3PT hitch. The 06 series could have 2PT hitches on them, Just walk on by them they are out dated, and the equipment for them is only usable on a 2PT system. I don't care for 3Pt equipment either so I like trailer implements. If you get a Standard or Western version tractor they wont have the 3PT hitch system so you will be stuck with only pull equipment.
John S.B. gave some pretty good advice. You'll find that almost everyone on here is partial to one color or another. In my opinion, color doesn't make any one better than the next. Personally, I like the Massey Fergusons, but that's just me. In my area, parts are easy to come by and there's at least 4 dealers within a 50 mile radius. Talk to the other farmers in your area and see what they have. You can do alot with tractors in the 60 hp range and the tires, parts and equipment isn't as expensive as the 100 hp range unless you will have to do a lot in a short time. Just my thoughts, Keith
Helped my cousin farm no-till row crop in Indiana for over ten years. Approx 500 acres with a 1466, 1066, and 886. You cannot get a better value to horsepower tractor than a 1066 or 1466. These tractors are also usually easy to repair. The turbo chargers make them real snappy, as they are old plow tractors. Beware of ones that have had the pump turned up - these engines can spin a rod bearing once in awhile. Souping them up with more fuel will make this happen quicker.
Got to agree with John, need more info. Are you going to be no till'n or work'n it to bug dust? What budget are you look'n at? What color iron is out front of the best/closest dealer?
Another queston most folks here won't ask but means alot, what are your reasons for farming this ground? Are you try'n to make a buck, just want something to do, or take'n care of the home place, or use'n it as a shelter from Uncle O? 160 acres of commodity priced crops you are going to have to be very carefull with every buck you spend to ever make it cash flow.
Good luck.
Dave
PS, I am a ford man and you can still find some good deals in X700 line that are in great shape.
The number in the X spot will depend on what you need to pull. Again, good luck.
Just right off the cuff I'd say a 1070 or 2090 Case, 966/986 IH or, or TW 5/10 Ford. I understand you are looking for general input but there is still a lot of variability as to location and what you plan to pull. I say this because the term 'dryland' tells me western, or at least west of here US. I'd never dream of needing a 100 hp to farm 160 acres in this part of the country. With 700 acres here and two operators 86 hp has been way more than enough until this year when I lost my dad, and half my workforce. As I needed to add some bigger equipment to compensate I've realized I dont have the hp capacity to spare so I'm adding one 108 hp unit to the mix. With 160 acres I'd be very content with a 76/7700 Ford, 666 thru 886 IH, or a 2955 JD.
What do you have a good local dealer for? That's the brand I'd start with. You'll be kicking yourself all OVER the place if you buy something that you can't get parts or service on without driving for hours or waiting days.
I'd start going to farm sales and look for package deals depending upon what equipment you want. Equipment has to be sized to the tractor and vice versa. Doesn't do any good to save a grand on a tractor deal and then pay a gazillion trying to find equipment to match and vice versa. How much time do you want to spend? A grandfather may have used an M to farm it back in the day.
Well I'd just though I'd start you down the path, I'm not really experienced enough to tell you what's good for you for a farm your size. (Heck, I had to google dryland farming) But you're in the right place. I practically learned how to bale hay on this site, although nobody here was kind enough to tell me I was crazy for wanting to bale for "fun". ;^)
Anyway, good luck and just do a search here on whatever question you have, I'm sure it's been discussed. And glance through all the photo ads to see what the price ranges are for equipment and tractors.
No single tractor will be enough. Now way back when a farmer would do all he needed to do no a place like that with an 8N ford but now days that would not cut it. You will probably need at least 3 tractors so as to have all the set ups you need plus have a way to fall back and keep going.
Because you said used I asume money is a consideration. So I would get an old IH like a 1066. Those engines were battle proof and you can get a lot of hp for the dollar.
I have a 1650 with loader and a 2470 does my 160+ acres verey nicely I paid $2500 for each tractor and have done a little repairs and find there not hard to work on.With 2470 I could use another 100 acres or more but that will come in time.
I already own a great little Ford 8N and I have a good friend who works on tractors here (I live in Northeastern Colorado). I have plenty of resources to purchase a tractor and get it repaired, no problems there.
I'll probably be growing wheat and alfalfa and raising about 20 head of Black Angus.
I hope this helps, do this rookie a favor...give the Make of the tractor along with the numbers so I won't get too confused.
Great input so far, I'm printing out the answers for my personal use.
I think the IH 966 - 1066 would be a good choice, you could pull a pretty good disk, cultivator, and any planter. Then again, 2 tractors would be better, maybe a Case 430-530, MF 135, Ford 2-4000 for a smaller tractor with 3 pt. I would stay away from John Deere. They are good tractors, almost everyone has one, but according to the classifieds they are all rare, lol! Comes down to your budget and what dealership is close.
Heavy draft cultivation? Hills, clay soil, mud, snow? Loader work? How handy are you to make light and heavy repairs? Any local dealers? Plans for 5 or 25years usage of this tractor? Require a cab for snow,rain, heat or dust protection?
