Tractor - trailer question
Ken Macfarlane
Putting axles under a nice used 14 ft Knaphide flatbed off a truck to haul stuff around the farm. Frame width on flatbed is 34" as standard but has triangular braces out at each crossmember.
My plan was to get the rear frame of a cab chassis 1 ton or F450 with 34" rails (hopefully with a hoist) and gut the diff and bolt the bed on.
Can't find any old trucks to cut up for cheap so I found a pair of new 6000 lb axles c/w brakes springs and hangers for about 750$ but can't have that much over hang from springs to backing plates.
Is it pretty standard to just weld some 2x2 1/4" wall tube under where each spring hanger is?
Hard to say without seeing it but torsion axles don't need spring hangers and are just welded on. You're going to need a frame under the deck though if you want to carry 5 tons or so.
I used 4"x1/4" channel cut long enough so you can weld spring hangers on for both axles , then welded the channel under the truck bed. made nice 20" goose neck trailer that way. make sure you are going to have enough room for the tires when loaded and take a measure from the center of the ball hitch to your first spring hanger to make sure it travel straight, don't want your trailer to side track. good luck with it.
How wide are the axles? If it's 18" from frame to springs that will be stretching 2x2 tube. What are you going to need to get clearance above your tires? You probly have room for 2x4 tube and that would be better unless you have fairly narrow axles and only need to go about 12" outside the frame. Use either tube or channel of what ever height you need to get clearance in one step to keep it stable. Make sure you put a crossmember at each spring hanger to keep everything from flexing when turning. What do you mean by "c/w brakes"?
I will add that when doing the rear axle measure from the front axle hanger not the front of the trailer. If you are off a little on the front it will dogtrack but if you are off between the axles it will scrub the tires off.
I haven't picked my axle face width yet, I was thinking since the bed is 96" wide the hubs face is something like 80" with spring pads at 60-66" or so? I have no idea what is standard.
It has a 6 or 7" channel frame now, just its at 34" centres to sit on a truck frame. Came off a 5 ton.
Other option is to put spring hangers off a 1 ton on the existing frame and use a dually truck axle and surge brakes.
There really isn't a standard. That hubface should be good. I always go with minimum hub/spring spacing to reduce the likelyhood of bending the axle. If it was mine I would get 2 channels 6' long what ever height you need to get your tires under the bed and reach to the crossmembers. Weld your suspension to them and them directly to the crossmembers. Put cross members the same size as your main rails from your main rails to the suspension rails and between your main rails. Then what ever you need to go from under your mains to the bottom of your suspension rails all the way across. Do that at all 3 suspension hangers. That will give you the strongest, and probly cheapest, answer. Channel is cheaper than tube and less likely to rust out. When ordering axles remember there are dozens of spring/suspension combos so that will affect what you need for beam height. If it was mine I would use one of the slipper spring combos rather that twin eye springs. I've had better luck keeping the axles aligned with those.
Thanks, I'm thinking I may rob the axles off my 27 ft flatbed and do just that. Its in such poor shape it shouldn't be on the road anyways.
Using a wagon running gear would be quick and easy plus a bolster hoist could be added if you wanted a dump. Brakes would be an issue, but you stated you just wanted to use it around the farm.
Are these pictures of any help to you? These are proper built for the purpose farm tipping trailers, made in Northern Ireland.
Sorry the chassis pics are not clearer!
Sam
Bolster hoist, I have never seen one of them here other than the scissor hoist part on a dump body. Too bad I live next to Maine, pretty far out there.
