I have an ORC, it happened so fast, there was no chance to hit the brake. Tractor spun around and had the broken limb under the rear tire and the tractor became wedged, came to a stop, didn't stall, the right wheel kept turning and digging in. I was knocked down, after the limb hit my back still in the seat. I don't know how long it took me to be able to reach around and turn the key off.(quoted from post at 12:51:49 09/28/23) MD Yes Gotta be careful, and I hope you have a
speedy recovery. One question Im thinking that
640 likely does not have a two stage clutch, so as you
try to stop quickly, the momentum of the brush cutter
pushes you. If you have not already, buy an over riding
one way clutch for your PTO shaft. You will be able to
stop the tractor a lot faster in emergencies.
I'm not doubting you, but what makes you say it's not a 640. Right after I got it in 2006 I sent pics of all the serial numbers I could find to this forum and the consensus was 640 mutt with non stock sheet metal so that's what I went with.(quoted from post at 14:26:01 09/28/23) Believe me, it is a 63, 64, or early 65 4000.
