Thanks. That will help. Hope it is something that was messed up when they mounted it. May not get to it today as I have a few cemeteries to get to.Look at the valves numbered 11 in the attached diagram that come in the side that mates to the engine. Make sure they are free. That engine is a full flow filtration system.
CNHI parts diagram
Found the pics when I mounted it 3 years ago. Flywheel had 22 thousandths taken off to reface it. There isn't enough clearance with the flywheel mounting bolts to get the spring side of the organic clutch disk in to the flywheel and still have the contact surfaces touch (edit) so the only way it went in was spring side into the "pressure plate" (edit). I didn't remove any bolts on the pressure plate but when I originally mounted it this piece of key stock about 3 inches long fell out of it which is laying on the board in the pic. Don't know what it was for. Have to load pics from computer later.
