Frontranger
Howdy folks: I have taken on a new project here at home on the front range, and have commenced to re-wiring a used trailer I bought recently. I'm now starting to make some of the connections, and am pretty happy with the progress so far. I'm using crimped AND soldered connections with a shrinkwrap covering on my terminal ends inside the plug housing (a 7 pin plug). Everythings fittin' together pretty good and am just about ready for the final assembly. I've read much about using dielectric grease on the connections for corrosion protection, and I don't want to put too much on, but I don't know what too little would be, other than just saying I put some on without really doing it. Would you use just a dab on both one side or on both sides of the terminal (a ring type terminal in this case, 12 & 10 AWG with a #10 stud hole)or do you try to cover the terminal and the post it is screwed to with the grease? Thanks fer yer help!
