Trailer Queen Hauling
Anonymous-0
When you guys with trailer queen N's haul them, how do you tie them down on the trailer without ruining the paint job? Goofy question, but I just got my full restoration running after being apart for nearly four years. Sure hate to mess it up! Thanks.
Tom........I ain't gott NO TRAILER QUEEN, its a worker, I use a 16ft flatbed trailer. ...BUT... I put some 5/8's EYE bolts in empty front axle holes to hook a custom made front axle bridal with hooks (thats a "Y" chain) to pull front wheels against a custom STOP-BAR with chain-tightener.
I have a "loop" that fits the 11-hole drawbar that I then hook a come-along to. It then STRETCHES the tractor from front axle chain-down.
And finally, I have a 2"-wide BELT that I strap OVER the tranny with some "corner protectors" that are non-marring plastic/paper stuff. Belt has built-in "J-HOOKS" that catch some trailer side pockets and then I use the built-in RATCHET to pull the tractor DOWN-TIGHT. Simple, eh?
Oh yeah, wheel chocks all around, they keep Barney happy. .......Dell
Here is a pic of my set up. I use the eyebolts up front, and use the under axle draw bar bracket for the rear. I have more pics with greater detail. Contact me if interested. Philip.
I use a two inch belt with a thick towel laid across the tranny and belts on bumper forward and to rear hitch. Towels prevent scratching, but more importantly, they keep the belts from starting a tear on the edges so they don't fail.
Brakes locked in low gear.
[b:b72d91deb8][i:b72d91deb8]
Jim;
That would keep the "N" from comming loose, when ya brake suddenly to avoid running over wayward DUCK'S ......right???? :lol:
Gary :roll: [/i:b72d91deb8][/b:b72d91deb8]
Yep.. like the others said.. old fire hose to run chains thru.. ratchet straps in some places, and leather or fabric pads under chains.. all work.. etc..
soundguy
