DENNIS MIN
All,
I absolutely abhor fixing trailer wiring, unless I can do a complete replacement with new stuff. Anyways, I did not get my wish and had to repair some existing wiring for a trailer. I did the usual, find the broken wires, clean the grounds, check suspect splices, etc.
As I was going around, a few splices when cut apart, showed wires that were black. I know they won't take solder in that state, and they need replacement, so a crimp butt splice will have to do for now.
I felt bad about doing that kind of repair, so I went to the laundry room and looked through the chemicals I had on hand.
Carb cleaner: no; circuit contact cleaner: no; alcohol: no; gas: no; this went on and on until I had this left-over-from-who-knows-when jug of muriatic acid. I got a mix of baking soda and water for a neutralizer first, then poured a smidgen of acid into a tiny glass jar, the kind you see for jelly samples, and added acid to it. I dipped the stripped ends of the black copper wires into it and the stuf smoked the copper wires clean.
I then neutralized it with the baking soda mixture and made the splices. Not a chemist, but had to see if anything worked.
Time will tell,
D.
Time will tell,
D.
