TerryfromSWIowa
Because wench is a female and winch is a tool.
I can't think of any way that "if possible" could apply. Even if brand new it would go back with fresh grease and washed.Also - if possible, return in better condition than when received.
They are easily confused for the other. They both pull you in and if you don't have your
You speak the truth, especially about the red-headed ones.They are easily confused for the other. They both pull you in and if you don't have your
wiring protected the heat can cause a fire which burns you to the ground. Redhead
versions are the most dangerous.
K’kin’s is Farmersamm’s nickname for his significant other.Huh??
Setup here is with battery on trailer. What type of battery is best. Just replaced 4 year old deepWinch on the trailer needs a battery beside it. The 7th power wire back from the truck can not carry enough current for serious winching .
Counting on the trailer frame and in particular the hitch for a ground/chassis return connection . Is being overly optimistic.
The way that I understand it is that most batteries provide cold cranking amps, which is basically the ability to crank a large motor when it is cold out. Deep cycle batteries provide much less power at a time but for longer.Setup here is with battery on trailer. What type of battery is best. Just replaced 4 year old deep
cycle with a new one,1000 CCA. Deep cycle was much cheaper than automotive so what advantages
do both have ?
Starting batteries are designed to provide a short burst of intense amperage. Deep cycle batteries are designed to provide extended amperage at a lower level for an hour or more, depending on application.With a battery mounted on the trailer you only need the hot wire from your plug to the battery and both batteries will stay charged at the same time. No power to both with the engine not running with the switch off. I made long jumper cables to go from the truck battery to the winch on the trailer. I think I only used the winch a few times after mounting it on the trailer.
2 suggestions:
A) Run the wiring in conduit
B) Train the grandchildren
