I personally wouldn't use the left over 9n fluid in any of my CubsWhere should the level be visually through the top fill hole?
And it takes 90wt right? I was reading some guys said they were running the 90 wt mineral oil TSC sells? Anyone confirm? I got a bunch of that left over from filling up my 9N
Good to knowI personally wouldn't use the left over 9n fluid in any of my Cubs
I drained it once many years ago. But ill drain it again. I couldnt remember what fluid i used.Drain the transmission...then fill with 3.5 pints of 80/90 or 85/140 gear oil. The "full to here" plug is a small pipe plug on the left side of the transmission,sorta behind the brake rod. BUT....if you haven't drained it lately,drain it. Condensation builds up fast in a cub transmission. ( The thicker the gear oil the happier a Cub is)
Yes. Final drives are each separate. But.... having removed dozens of those pans we rarely find watery oil in them ( I guess because the ain't cast they don't sweat??) we usually just pump a little fresh oil in on top....thick is good in there85-140 is fine for down south in the winter but northern climates it would like more of an80/90 or even if you want to spend the money a75/90 synthetic oil. Not sure what the price difference4 is anymore. Been a few years since I bought any synthetic oils. I'm not sure but don't the wheel drives each have a separate reservoir for each wheel end? So you would need a bit more than the 3-4 pints. You could also probably run hytran in it but if the seals leak or seep now they will probably leak more and faster with hytran in there.
If by "left over" you mean the old oil that was drained from the 9N, I agree.I personally wouldn't use the left over 9n fluid in any of my Cubs
Bushing in reverse idler gear. Better to stick with GL-4 that is not also listed GL-5, or use Hy-Tran equivalent.My understanding is there is no "yellow metal" in a Cub transmission, so getting "safe" oil is not necessary.
No not used oil lol.If by "left over" you mean the old oil that was drained from the 9N, I agree.
However, if it is fresh new oil in a bucket that says "gear lube" there is nothing 9N specific about it.
Nope. We just add as much fresh as neededMine are not leaking and I am sure they have at least some of the original 72 year old oil - have you ever tried pumping the final drive out to get more "new" oil in them?
what he said!Drain the transmission...then fill with 3.5 pints of 80/90 or 85/140 gear oil. The "full to here" plug is a small pipe plug on the left side of the transmission,sorta behind the brake rod. BUT....if you haven't drained it lately,drain it. Condensation builds up fast in a cub transmission. ( The thicker the gear oil the happier a Cub is)
