(quoted from post at 09:49:52 09/13/10) Does anyone know of a way to fix a leak around the seal between the transmission and motor on a 1955 850 Ford, without tearing it down? Thanks!
If not how bad is this to break in to? Is this a job that a novice can do? The tractor place wants $700.
JIM-NC
(quoted from post at 14:49:52 09/13/10) Does anyone know of a way to fix a leak around the seal between the transmission and motor on a 1955 850 Ford, without tearing it down? Thanks!
JIM-NC
(quoted from post at 17:49:13 09/13/10)
In my opinion 500 to 700 is a fair price for input shaft seal. However when you split the tractor you may need to replace additional items, clutch, bearings etc.
Anyone that thinks a mechanic should grantee a patch job should open their own shop and try it for awhile....
