transmission fluid-cold weather
jhub
9N66963-Forgive me, as I am sure that this is a well worn subject, but i need some experienced opinions. I am changing my transmission fluid and I would like to know if I will be hurting anything if I use the GL-1 from NAPA in the winter. I am in northern Michigan and temps can jump down below 0 for a couple of days. Most of the time it's between 20 and 30 above zero. I know that it is slow in the cold but will there be any extra wear on the pump from pushing the cold thick fluid. Anyone using the NAPA #65-205 in cold climates? Thanks in advance for the info.
Jeff
The simple answer is "the heavy GL-1 won't HURT anything in cold weather, but the lift will be sluggish".
You can use a "Universal Tractor Fluid" meeting NH's "134" specs, (as most of those oils do) as a "lighter alternative" for the cold months.
I've found it as low as $25.00 a pail at WaldoWorld.
I'd go with the GL1. It won't hurt anything and unless all your seals are real good the thinner 134 spec. stuff will cause leaks. These old tractors were designed to use the GL1.
Jeff.........OIL is CHEAP. Ain't NO LAW that sez you can't change yer tranny oil 2-times a year.
Think about yer hydraulic application. Iff'n yer "plowing" in Michigan, where you NEED HYDRAULIC LIFT fer yer backblade, why don't you use the modern liteweight Ford/NewHolland spec: M2C-134D for yer wintertime use??? Then iff'n it don't work fer yer summertime hydraulic use, change to HEAVIER 90wt GL-1. Simple, eh?.........respectfully, Dell
I don't have an opinion on which to use. But with that said, I feel sorry for anyone who has to winter in Michican. Have a great day and stay warm.
Tennesse Man that is a good place to be from, ain't it, especially with temperatures like that, far away from. I have enuf of those temperatures during the winters here in Central NC. Brrrrrrrrr!!!!!!!
As the others have said, GL-1 is fine. The lift will be a bit slow tho. I live in N. central Il. What I usually do is go out and start-er up. Go back in the house for a coffe or two. By that time, things have warmed up and off I go.
HTH....have fun....don t. .....
I use the 134D stuff and don't have any problems with leaks. The 90 weight stuff is too slow for me in winters here in MO.
I run about half thin, and half thick in GA this summer.
I can run all thin, but mine don't seem to like the pure GL-1, and it is clean, but may not be quite adjusted to spec.
When the temps fall below 50 the 90 wt. is to slow for me, I run the thin stuff (134) in mine. Have I not read to mix #2 heat"n oil or diesel in the hydraulics for cold temp operation, sure seem"s I have.
I don"t buy into the tale that 80/90 will degrade the brass in a N"s hydraulic pump. B-4 I started hang"n out here I ran it no problem. Now I am skeered to he he. 80/90 would werk much better cold, hill 75/90 would werk better than 80/90. My old Toyota pic up will not shift cold with 90 wt. no problem with 80/90.
I spec it does work on the pump to try and push 90 wt when cold. I spec if I had to B out and it 20 degrees tyring to git the job done $35 bucks worth of oil would not play into the equation. I figger its the price you pay to not have to put up with skeeters year round. I spec most modern equipment runs some form of 134 oil and they don"t have a problems that I could point to the 134 as the problem. Most if not all FWD cars use automatic trans fluid to lube the differential. They bout never have ring and pinion problems, their are some high powered cars out their that will bark the tires rite good.
Your call, me i am not 2 much for wait"n for it to warm up and would go with the 134 in your case. The 90 wt. would B used if I had hydraulic issues. Ware on the pump would not B a issue to me.
<a href="http://www.hobos8ns.com/">
<img border="0" src="http://www.hobos8ns.com/Graphics/Hobo-logo-avatar.gif" width="242" height="72"></a>
