I just got this 49' 8N running that I flushed the rear and trans and filled with new Hi-Tran. I have a leak from the cotter pin that is right in front of the Trans drain. My guess from looking at the I&T shop manual is it might be from the counter shaft. Any advice would be appreciated. I just bought this tractor from a guy who had it as a lawn ornament for the last ten years and when I checked the trans and rear fluid it was low so I suspect when I flushed filled to the marker on the stick it is at a higher level and now leaks. Just thought I would get some advise before I pull it apart. I am restoring so I want to go after the leak.
