Karl Kostman
Hey guys My 1959 730 is almost ready for the field but I would like to change the transmission lubricant prior to that. The book says to use SAE 90 weight oil, this is not gear lube this is oil correct? The only oil I know of that is 90 weight is gear lube. Is what they are referring to gear lube or is it a straight 90 weight oil? The next question id the manual says the transmission should hold approx. 8 gallons and then I am supposed to add another 1.5 quarts through the 2nd gear reduction cover? The manual I have is great in some sections but leaves me with questions such as this in others, any clarification on the lubricant types would sure be helpful.
Thanks much!
Karl
Thanks much!
Karl
