Hello Folks
My MF 165 (A4.212) won't start. Very embarrassing cause it (didn't) perform for my visiting brother-in-law, who has a collection of at least 7 MF's.
It cranks fine but with absolutely nothing from the injector pump, either in the form of white smoke, or fuel when the injector pipes are cracked off.
So I have checked the archives and taken the following steps:
Checked cut-off wasn't on and gave the throttle a workout to make sure nothing inside the injector pump was stuck
Replaced the fuel filters and cleaned pipe work from tank to injector pump (primary filter was completely blocked, bled system several times after this but still no go). There was a lot of water in the filters and fuel tank.
Removed the fuel tank and cleaned it (quite a bit of fine crud, plus a large bolt ?? inside)
Cleaned the fuel tank tap (crudded up with some gell stuff, also lots of Teflon tape !!)
I've also adjusted the tappets while the tank is off.
I checked all pipe work, and did find a loose fitting on the injector return pipe that goes back to the tank - would this stop the tractor from bleeding properly and running ??)
Tonight I'll check the functioning of the fuel lift pump and install a kit if necessary.
Is there anything else I should do, or that I have missed
