Well...I made a (hopefully) slight mistake the other day with what I believe is an IH 444 tractor (one of the stamped markings was 3044048R2). An old PTO connector was seized up on the tractor PTO shaft so I removed the bolts for the shaft guard to gain better access. Because of the amount of oily dirt built up on the rear end of the tractor, I missed that these bolts were also what held the rear PTO shaft main seal in place. I decided to leave the cover guard off until I was finished using the tractor and...you can probably guess... the rear PTO shaft pushed out of the housing while using the PTO. I turned the tractor off within a minute of the issuing happening. I was able to slide the rear shaft back into the internal sprocket, cleaned off the old gasket, installed a new gasket, and then checked the oil level via the plug on the left side of the tractor. However, when I went to restart the tractor, it is completely dead and will not even attempt to turn over. Based on some research on this site it appears that there may be an interlock in play, but I couldn't find more than a passing mention of them. I am hoping that some one can help me get this tractor running again.
Thanks, Evan
Thanks, Evan
