Over the winter I attempted to repair a hot no start on an older Nissan, I came away thoroughly disgusted with the lack of quality in the aftermarket parts market. After three bad igniter/ignition modules in a row from two different companies, I ended up using 30+ year old original equipment junkyard components. On the wife's Civic last spring I chose aftermarket, complete lower control arms instead of replacing bushings and ball joints only to find when having the car aligned - they are shorter than stock - affecting the camber for which there is no adjustment. Don't get me started on aftermarket brake rotors that need turning after 6000 miles. A year ago I went through three thermostats before getting one that opened at the temperature it was stamped with.
TRW and Dorman used to be solid. Niehoff and Standard Ignition the same. In 2022 I bought a bunch of AC Delco/GM "Made in USA" boxed air conditioning parts for my Tahoe only to find "Product of China" stickers on some of the parts. China does nothing well.
Where do you go for your old tractor or vehicles parts when there is no longer OEM parts available?
