Anonymous-0
1.Union Diesel Parts Co.,Ltd is a Replacement part manufacturer&Distributormembers).
2.Diesel fuel injection system component are our major produce. we are a constant partner
to our customers, from the planning stage right through service.In short,We don't just sell a product, We offer complete soluations.
3.many years experience in diesel fuel injection system making .
4.Hundreds of coustomers all over the world.
5.Thousands of kind components produce ability.
6.We will of course continue to do so in order to meet the increasingly complex requirements of our customers and find solution.
Visit our websit: http://www.undiesel.com
Contact name :Mr Chen
address: No.10,Lihan Road,Liyuan Industrial Park,Putian City,Fujian Province,China
Email: [email protected]
MSN: [email protected]
Tel:+86-594-2226395
diesel fuel injection part, diesel element, diesel plunger, diesel barrel, caterpillar, bosch, denso,zexel , STANADYNE, YANMAR, AMBAC INTERNATIONAL, LUCAS-CAV, hydraulic head, cylinder/ distributor head, head rotor, military truck part, hd90100, nsn 2910008287176, m35 series, m series, caterpillar diesel, pencile nozzle, 8N7005, ZEXEL, BOSCH, DENSO, DELPHI, military part, military vehicle engine part, armoured vehicle part, diesel part, diesle injector, diesel injection, ZEXEL, BOSCH, DENSO, DELPHI, LUCAS-CAV, STANADYNE, AMBAC INTERNATIONAL, CAT, MTU, KOMATSU, TOYOTA, SUZUKI, NISSAN, MAZDA, HONDA, HINO, cylinder head, hydraulic head, head rotor, nsn 2910008287176, hd90100, nsn 3040007223536, hd8821,
military vehicle part, car part, cummins, komatsu, cat, caterpillar, diesel injector, caterpillar diesel, pencile nozzle, cylinder/ distributor head, ve-pump
fuel pump;ac delco fuel pump;ac fuel pump;aeromotive fuel pump;alero fuel pump;alfa romeo
;ambac;ambac international;audi a4 fuel pump;audi fuel pump;auto diesel parts;auto fuel pump;automotive fuel pump;barrel;bedford ;bedford 500;BEDFORD kit;belts hoses;BMC 1500;BMC 4/98;BMW;bmw fuel pump;bmw idle control valve;bnc 1500;bosch;bosch delivery valve;bosch diesel fuel injection;bosch diesel fuel injection pump;bosch diesel fuel injection pumps;bosch fuel injection pump;bosch fuel pump;bosch hydraulic head;bosch idle control valve;bosch injection;bosch pump;bosch ve diesel injection pump;bosch ve diesel pump;bosch ve fuel injection pump;bosch ve fuel pump;bosch ve injection pump;bosch ve injector pump;bosch ve pump;bosch ve pump parts;broken cross disc;bryce;Cam Disk;cam disks;Cam Plate;Cam Plate ;cam plates;camaro fuel pump;camry fuel pump;car fuel pump;caravan fuel pump;carter fuel pump;carter fuel pumps;case ih;Cat Pencil Nozzle ;Cat Pencil Nozzle ;caterpillar;cav fuel injection;cavalier fuel pump;CDC/PERKINS;chem feed pump;chevrolet fuel pump;chevy truck fuel pump;CHRYSLER;cleaning fuel injection;control arm shaft;control arm shaft kit;Control Cover;control covers;Control Shaft;Control Valve;control valve chrysler;control valve india;control valve manufacturer;control valve manufacturers;control valve parts;control valve price;control valve type;controle valve;controle valves;controlled valves;controls valves;Cross Cube;Cross Disc;cross roller ring;cube cross;CUMMINS;cummins 4bt;cummins 6bt-5.9;cummins cam plate;cummins cup;cummins delivery valve;cummins diesel;cummins diesel fuel injection;cummins engine parts;cummins fuel injection;cummins fuel pump;cummins injector;cummins injectors;cummins system;cummins ve pump;CUMMINS:4BT;CUMMINS:6BT-5.9;D.Valve;dakota fuel pump;DEL. Valve;delco fuel pump;Delivery Valve;Delivery Valve ;delivery valves;Delivery-Valve Assembly;delkron cam plate;delphi;delphi fuel injection;denso;denso fuel injection;denso fuel pump;DEUTZ;DEUTZ/KHD;diesel bosch;diesel delivery valve;diesel elements;diesel engine;diesel engine fuel injection;diesel engine injection;diesel engine part ;diesel engine part ;diesel engine parts;diesel engine parts ;diesel engine spare;diesel engine spares;diesel engines;diesel feed pump;diesel fuel;diesel fuel cleaner;diesel fuel cleaning;diesel fuel distributor;diesel fuel engine;diesel fuel filter;diesel fuel filters;diesel fuel injection;diesel fuel injection ;diesel fuel injection equipment;diesel fuel injection equipment ;diesel fuel injection nozzle;diesel fuel injection part;diesel fuel injection part ;diesel fuel injection parts;diesel fuel injection parts ;diesel fuel injection pressure;diesel fuel injection problems;diesel fuel injection pump;diesel fuel injection pump ;diesel fuel injection pump parts;diesel fuel injection pump test;diesel fuel injection pump test bench;diesel fuel injection pump test equipment;diesel fuel injection pumps;diesel fuel injection pumps ;diesel fuel injection repair
;diesel fuel injection service;diesel fuel injection services;diesel fuel injection specialists;diesel fuel injection system;diesel fuel injection system ;diesel fuel injection systems;diesel fuel injection systems ;diesel fuel injection timing;diesel fuel injections;diesel fuel injector;diesel fuel injector ;diesel fuel injectors;diesel fuel injectors ;diesel fuel nozzle;diesel fuel parts;diesel fuel pump;diesel fuel pumps;diesel fuel system;diesel fuel systems;diesel fuel transfer pump;diesel injection;diesel injection ;diesel injection equipment ;diesel injection equipment ;diesel injection part ;diesel injection part ;diesel injection parts ;diesel injection parts ;diesel injection pump ;diesel injection pump ;diesel injection pumps ;diesel injection pumps ;diesel injection system ;diesel injection system ;diesel injection systems diesel injection systems ;diesel injector;diesel injector ;diesel injectors;diesel injectors ;diesel kiki;diesel lucas;diesel motor;diesel nozzle;diesel part;diesel parts;diesel plunger;diesel pump ;diesel specialists;diesel tester;diesel truck;diesel turbo;diesel zexel;dipaco;disa;disc cam;disc cams;dodge dakota fuel pump;dodge fuel pump;dodge neon fuel pump;doowon;double regulating valve;Drive Shaft;Drive Shaft ;driveshaft;e30 fuel pump;efi fuel pump;Electric Governor;electromagnetic valve;element;elements;engine fuel injection;Equipment;f150 fuel pump;fass fuel pump;Feed Pump;Feed Pump ;feed pump turbine;feed pumps;feeding pump;feuling cam plate;fiat/allison;flo control valve;FORD;ford/nissan;fuel bosch;fuel engine;fuel engines;fuel feed pump;fuel injection;fuel injection ;fuel injection equipment;fuel injection equipment ;fuel injection nozzle;fuel injection part ;fuel injection part ;fuel injection parts ;fuel injection parts ;fuel injection pump ;fuel injection pump ;fuel injection pumps ;fuel injection pumps ;fuel injection system ;fuel injection system ;fuel injection systems ;fuel injection systems ;fuel injections;fuel injector;fuel injector ;fuel injector nozzle;fuel injector pump;fuel injectors ;fuel injectors ;fuel nozzle;fuel pressure regulating valve;fuel pump;fuel pump;fuel pump assembly;fuel pump kit;fuel pump parts;fuel pump plunger;fuel pump price;fuel pump prices;fuel pump problems;fuel pump repair;fuel supply pump;fuel valve;Fulcrum Lever;garrett;Gasket;GM;gm fuel injection;gm fuel pump;gmc fuel pump;gmc jimmy fuel pump;Governor;Governor adjusting;Governor Cover;harley cam plate;hartridge;head pump;Head Rotor ;Head Rotor Lucas ;Head Rotor Lucas ;HeadRotor Nozzle ;Head Rotor Nozzle ;,head turbine;holley fuel pump;holset;HONDA;honda civic fuel pump;honda fuel pump;honda idle control valve;honda pump;honeywell pressure regulating valve;how diesel fuel injection;Hydraulic Head;hydraulic head loss;hydraulic head pressure;hydraulic heads;hydraulics head;iceco-8140;idle control valve problems;in control cover;injection engine;injection nozzle;injection parts ;injection pump;injector;injector nozzle;injector pump;injector pumps;injector valve;injectors pumps;integra fuel pump;interchangeable;interstate mcbee;ISUZU;ISUZU 4JB1;ISUZU 4JB1T;ISUZU PK;IVECO;IVECO 40-10;IVECO 40-8;IVECO 49-12;IVECO/RENAULT;IVECO-8060;IVECO-8140;jeep cherokee fuel pump;jeep fuel pump;jeep wrangler fuel pump;jetta fuel pump;john;John Deere;KOMATSU;LAND ROVER 2.25;LEYLAND 680;lucas;lucas diesel fuel injection;lucas fuel injection;lucas no;lutong;m35a2;M35A2 truck;m60;Magnet Valve;Magnet Valve ;magnet valves;magnetic valve;magnetic valves;malibu fuel pump;marine diesel fuel injection;marine fuel injection;masoneilan control valve;maxima fuel pump;MAZDA;mazda fuel pump;mercedes diesel;mercedes diesel fuel injection;mercedes fuel pump;mico;mikuni fuel pump;military truck;military trucks;military vehicles;MITSUBISHI ;mitsubishi 4d55;model 100;motorpal;MWM D225/6;neon fuel pump;nippen denso;NISSAN;nissan cd17;nissan fuel pump;nissan td27;nissan td42;Nozzle;nozzle engine;nozzle holder ;nozzle manufacturer;nozzle manufacturers;nozzle size;nozzle sizes;Nozzle Tip;nozzle tips;nozzle types;nozzles;nozzles tips;offset control arm shaft;oil feed pump;omap;other no ;panasonic roller ring;passat fuel pump;Pencil nozzle;perkins 3 cyl;perkins 4 cyl;PERKINS 6 CYL.;PERKINS 6354;perkins t6354;pierburg fuel pump;Plunger;Plunger ;plunger barrel;plunger oil pump;plunger pump;plunger pumps;plunger type pump;plunger valve;plunger valves;plungers;powerstroke fuel pump;pressure regulating valve;pressure regulator valve;pump;pump assembly;pump control valve;pump fuel;Pump Housing ;pump hydraulic head;pump injection;pump injectors;pump nozzle;Pump Plunger;pump rotor;pump valve;Regulating Valve;regulating valve india;regulating valves;renault;Repair Kit;roller assy;roller ball bearing;roller bearing;roller bearings;roller racing;Roller Ring;roller rings;roller shaft;rotor turbine;s10 fuel pump;saab fuel pump;samsung;shaft drives;silverado fuel pump;snowmobile fuel pump;spaco;Speed Control;Spring;spring plunger ;stanadyne;su fuel pump;subaru fuel pump;supplier pump;Supply Pump;supply pumps;tahoe fuel pump;tdi fuel injection;tdi fuel injectors;tdi fuel pump;testing fuel injection;TOYOTA;TOYOTA 14B;toyota ihz;Triplex coupling;triplex plunger pump;turbine nozzle;turbo diesel fuel injection;turbo fuel injection;turbo nozzle;turbocharge;unit fuel injection;upper control arm shaft;us5 in control cover;valve;valve pump;valve system;valve systems;ve diesel injection pump;ve diesel injector pump;ve diesel pump;ve fuel injection pump;ve fuel pump;ve injection pump;ve injector pump,ve pump;Ve Pump;ve pump kit;VE Pump Parts;ve pumps;vehicle model ;VOLVO;volvo penta;walbro 255 fuel pump;walbro fuel pump;walbro fuel pumps;watts regulating valve;weldon fuel pump;wilkins pressure regulating valve;wrx fuel pump;yanmar;yanmar fuel
injection;yanmar fuel injector;zexel;ZEXEL NO;zexel ve pump
AEC505;AIDO(CN);ALFA ROMEO;ALLISON;AUDI;AVL;BARRIEOUS D26;BARRIEOUS D36;BEDFORD;BEDFORD 500;BEDFORD KIT;BENC;BENFRA;BINGCHAI;BMC;BMC 1500;BMC 4/98;CA4DF2;CA6110/125;CA6DF1-28;CA6DF2D-21;CARTR;CASE IH;CDC;CHANGCHAI;CHANGCHUN40 495A;CHANGJIANG;CHAOCHAI;CHAOCHAI4102;CHAOCHAI6102;CHAOCHAI6102(6BD1);CHAOCHAI6102BZQ;CHII;CIEFANG;COASTER;CUMMINS;CUMMINS 6BT5.9 ;CUMMINS/EXPORT;CUMMINS:4BT;DACHAI;DACHAI 6DE;DACHAI6110;DACHAI6113;DACHAICA498;DAEWOO;DAEWOO/EXPORT;DAF;DAFA;DAIHATSU;DALIAN;DALIAN DIESEL MANUFACTURER;DALIAN DIESEL/EXPORT;DEUTZ;DEUTZ/EXPORT;DOMATSU;DONFENG;DONGFANGHONG;DONGFENG6 CAT210;DONGFENG6 CAT240;DONGQI SAW;DORMAN;ENGINEELING;EQ153;EXPORT;EXPORT0;FIAT;FORD ;FORD TCTOR 3CYL;FORD TRACTOR 3CYL.;FUJIHEAVY;GOANGXILIUFA;GOLDEN;H06C/H06CTA;H07C/H07C-A;HAEP;HANGFA;HANOMAG;HECHAIBR-TD234;HINO;HINO Isuzu;HINO/BOSCH;HINO/EXPORT;HKR;HUDONG6105;HYUMDAI;IHC 4CYL;IMITSUBISHI;INTERCHANGEABLE:;INTERCHANGEACE:;INTERNAT IONAL;ISEKI;ISEKIISUZU;ISHIKAWAJIMAS;ISHI-SHIBA;ISUZU;ISUZU 4FB1T;ISUZU 4FCI;ISUZU 4JB1;ISUZU 4JB1T;ISUZU 4JB2;ISUZU PK;ISUZU/BOSCH;ISUZU/EXPORT;IVECO;IVECO 40-10;IVECO 40-8;IVECO 49-10;IVECO 49-12;IVECO/35-10T;IVECO/8140-27;IVECO/VE R 573;IVECO40-10T;IVECO49-10T;IVECO-8060;IVECO-8140;JICHAI Z12V-190B;JMC;JMCTFR4JB1-NA;JOHN DEERE;KHD;KINGLONG/EXPORT;KOMATAU;KOMATSU;KOMATSU/EXPORT;KUBOTA;LAIDONG;LAIDONG480 485 495;LAND ROVER 2.25;LEYLAND;LEYLAND 680;LIUFA6105;LUOYANG TRACTOR 105;M.BISHIHI.NAG;MACK 676;MADE INJAPAN;MAN;MAND2865;MAZDA;MAZDA/EXPORT;MAZDAN54;MISSAN DIESEL;Mit/EXPORT;MITSUBISHI;MITSUBISHI 4D55;MITSUBISHI HEAV;MITSUBISHI/EXPORT;MITSUBISHINM12;MWM D225/6;NANCHONG DIESEL MANUFACTURER;NANJING;NAVISTAR DTA-466;NFD150;NHR;NHRNKR;NIIGATA URAWA/NIIGATA TEKKOU;NISSAN;NISSAN AD23;NISSAN AD27;NISSAN CD17;NISSAN D20-T;NISSAN DIESEL;NISSAN DIESEL/BOSCH;NISSAN DIESEL/EXPORT;NISSAN
DIESELISHIKAWAJIMAS;NISSAN TD42;NISSAN/EXPORT;NISSAN-D;NISSANTD27;OPEL;PERK;PERK 3CYL;PERK 4236;PERK 4248;PERK/MF 3CYL;PERKINS;PERKINS 3CYL;PERKINS 4CYL;PERKINS 6354;PERKINS 6CYL;PERKINS T6354;PERKINS/MF 3 CYL;RBTR;RENAULT;RIAZ;RUSSIAN TRACTORS;SAMSUNG;SAW;SDEF;SEAT;SF498G;SHANFCHAI;SHANGCHAI/186/WF;SHANGCHAID6114;SHANGCHAIG6135;SHANGHAI;SHANOS;STEYR;STEYRWD615 X6130Q;TATRA;TFR4JB1T;TIENTSIN;TOYO-SHA;TOYOTA;TOYOTA 14B;TOYOTA 1HZ;TOYOTA/EXPORT;TS230;USE HR04;USE HR11;USE HR45;VMW;VMW-X;VOLVO;VOLVO PENTA;VOVLO ENGINE;VW;VW(CK);VW(ME);VW(ME)/VE R 270;WD615;WD615.46HANGFA;WD615.67;WD615.68;WEICHAI;WUXI;XICHAI;XICHAI4110;XICHAI6110;XICHAI6110(6D14);XICHAI6110A;XICHAICA6110;XIEFANG;XINGCHAI;YAMAHA;YAN'AN;YANGCHAI;YANGCHAI4102QI;YANMAR;YANMAR/EXPORT;YC;YC4110Q;YC4110ZLQ;YC6112;YC6112ZLQ;YELLOW RIVER;YUCHAI;YUCHAI4110Q;YUCHAI6105QC;YUCHAI6108;YUCHAI6112;YUCHAI61DB;ZB400KUBOTA
20494;23836;26632;26964;27333;27836;28481;28485;29279;32262;33408;800001;800320;800717;800858;800859;0 330 001 015;0 433 171 214;0 433 175 031;0 434 250 072;0 434 250 103;0 434 250 128;0 434 250 176;0 434 250 898;0 460 484 006;093400-1330;093400-5320;093400-6190;096140-0030;096400-0143;096400-1250;096400-1330;1 418 325 096;1 467 010 059;1 468 334 327;1 468 334 946;105000-1130;105007-1120;105015-3280;113 VW;131151-3220;134101-6420;146405-1920;146600-1120;2 418 425 988;2 418 425 989;2 418 450 011;2 418 455 122;2 418 455 129;2 418 455 165;2 418 455 580;2 468 335 022;2 468 336 013;4W7016;7123/340U;8N7005;BDL30S46;DLLA144P184;DLLA146P197;DLLA150P24;DLLA150P43;DLLA150P52;DLLA150P59;DLLA150P602;DLLA150P77;DLLA150P9;DLLA152P452;DLLA155P230;DLLA155PN118;DLLA158P7154;DN0PDN112;DN0PDN113;DN0SD1510;DN0SD193;DN0SD1930;DN0SD211;DN0SD2110;DN0SD220;DN0SD240;DN0SD261;DN0SD265;DN0SD273;DN0SD274;DN0SD293;DN0SD294;DN0SD297;DN0SD299;DN0SD301;DN0SD302;DN0SD304;DN0SD308;DN0SD314;DN10PDN130;DN12SD12;DN12SD290;dn12sn12;DN15PD609;DN20PD32;DN4PD1;DN4PD57;DN4S1;DN4SD24;DN4SDND133;dnosd193;dnosd261;dnosd265;dnosd293;dnosd297;DSLA145P208;DSLA145P366;DSLA150P357;DSLA150P442;DSLA150P502;DSLA150P520;hd90100;HD90101A;PN;PS7100;PS8500
Tel:+86-594-2226395
