Anonymous-0
Here's the question at hand. Say your turbo has a 2" dia air outlet for the pressurized air and you run the pressurized air through a 2" inside dia. pipe to the intake manifold. Lets say the opening in the manifold is also 2". Now if I was to go from the turbo into a 4" inside dia pipe to the 2" manifold would that make any difference in my boost pressure? If I went to to 4" pipe would I have to make the manifold inlet that big as well to make a difference in anything? Would that bigger volume pipe change boost pressure or would it even matter since its boost and not air going in at atmospheric pressure? Thanks
