Well, I got the engine to crank over with 12V pos ground and no plugs in the cylinders. I fixed the stuck valve in #2 cylinder with a light smack on the valve with the plug out. Put the new battery and cables on, added a temp gas tank, cleaned the corrosion off the points.
Hit the starter and it cranked over nicely.
You thought it would start?
HA!
Even I knew better.
Rather than waste a bunch of time, grab the meter and start looking for voltage.
Wonderful volt drop just through the ignition switch.
Rust on every connection and a lot of it not worth playing with.
Ordered up an ign switch and ballast resistor.
Don't want to wait for parts, grab the jumper wire and go from the battery to the ballast resistor.
Hit the starter button and it fired up with a great cloud of smoke from Seafoam in the cylinders.
Then from the noise, I could tell the starter drive was stuck.
Sun Beach Somewhere. Chop the throttle and the engine dies. Naturally we had to do it again.
Pull the starter out and naturally it came out in pieces.
Starter drive is stuck and will not retract or extend anymore.
No biggie. A trip to Napa tomorrow and a generous dive into the wallet to pick it up tomorrow.
It might be running Monday, after the rain stops on Sunday.
After that comes the multiple clean ups and other repairs.
HA!
Even I knew better.
