unwanted excitement
snoop-nc
Had a bit of &%^$ excitement late this morning. I had turned on lights in the shop (all florescent) to let them "warm up" and made sure A/C was also on when I fed the mare...came back inside for a bit and decided I was hungry. Went out for "brunch" and came home straight to the shop approx 2-3 hours after turning on lites. As soon as I opened the shop door, thought I smelled something unusual...got to "sniffing" and "looking" around and spotted a little bit of smoke drifting. I realized then that I smelled "electrical" problem. The long fixture over the main work bench was NOT lit up, but had lit up when turned on earlier. I got a step stool and touched the fixture and it was too hot to touch. Took the bulbs down...and the cover plate to find the ballast was bubbling and dripping black "oil". There are three switch circuits to turn on all the lights and this fixture is on a circuit by itself. Needless to say, I'll be doing some electrical work in the next couple days or so. This building was built in 1986 and the wiring was done professionally by one of the best electricians in the area. Have had no problems till now and feel very fortunate that no other damage was done.
Rick
many a ballast has ended it's life in a puff of smoke and dripping fluid. Switch to electronic ballasts and compatible bulbs and your slow starts will be over.
That black oil can have a really bad smell to it. We had the same problem in my shop, put some vinegar in a saucer and let it sit nearby for 3-4 days and the stink should be gone.
I just bought one of those T-8 fixtures to replace the old larger diameter bulbs because they are energy efficient and boy they are bright. Really made a difference.
