onalaskahoe
Hello all
My John Deere 310A backhoe has slow and weak hydraulics, the machine moves fine in both forward and reverse, and the steering is pulsy. Even with the RPM up over 2100 I still have slow and weak hydraulics. I have done the following and I will list the results.
1) Replaced the Hydraulic filter.
2) Replaced the Trans filter.
3) Removed and cleaned and replaced the Hydraulic intake screen. (There was very little dirt on the screen).
4) Removed the Hydraulic filter mount and checked the relief valve, it looked good.
5) Checked radial pump and pistons look great and o-rings look good and closed back up.
6) Replaced STROKE control valve.
7) Replaced system fluid with new fluid.
Now!!
The machine still has slow and weak hydraulics and with high RPM, but I did see today that after rising the loader I find that as I let it down I can hear the pump load the engine a little and if I stop and quickly use any operation of the hoe it has strong and fast action. This only last for a moment but if I use the stabilizers they will lift the machine right up off the ground and if I have the hoe straight out and on the ground, I can lift it right up fast and strong. And the loader is still slow and weak but if I let it down and the motor loads I can then at bottom use the down force and lift the front of the machine right off the ground.
So now my question is? Is there a bypass or something that I have mist that can cause this?
I have not checked the bypass for the Trans filter, and I have not yet checked the charge pressure to the hydraulic pump but with the trans forward and reverse working I thought that would show a good charge pump.
And when I check the trans pump pressure should I check on the hydraulic pump at top or bottom of the pump head ports. And for the reverser do I check at the plug on the back that is facing down?
Now!!
