update on loader problem
Tony in Mass.
I guess my post from last night is 3 pages back already. I took the power steering lines off, plugged everything up, added more fluid, that rams have a 1/2 inch of travel, the bucket cylinders don't seem to move at all. I can't believe it is airbound, but any ideas how best to bleed this rig out? I can't believe my try at PS did anything so serious to bring this on.... thanks in advance again!
I would think that the pump is not moving any fluid. Airlocked most likely. Try to prime the pump first.???
SDE
AS for air in the cylinder, consider that 15 PSI air from being open is going to be compressed by 2000 psi oil, making that air volume about 0.6% of the cylinder volume. Too little to worry about.
Gerald J.
Hi Gerald, I am sticking to Fergies from now on, had this 540 for 10 years now, never could keep power steering fluid in either end, pump is sad I guess -but in the process of curing these leaks and a few other small jobs, I go and do this. Yeah, after a few minutes any air should have rotated out- of lines or cylinders, but I have a feeling I did like SDE said- I deprimed the pump? the return of the power steering line I rigged up had a nice steady flow coming out into the reservior- the loader frame- I smell a fish in the 4 way valve, the last time I tore into one of those I nearly blinded myself, I was wondering how to bleed that off- safely....
