Matt Higgins
Hi all - posted a couple of weeks ago about the problems we were having with starting our 6v TEA-20, and thought I'd post an update (and ask more advice!!!).
As you may remember, not only were we getting a very sluggish spin of the starter, but the switch didn't seem to be working. So I moved the switch forward to make it more sensitive, nothing. Took it off and tested it with a test lamp, nothing. Took it to bits and it seems that the spring at underneath the contacts has either come away or broken. Sort of bodged it, tested it again, worked. Put it back on the tractor, gearstick start test worked. Put everything back together, didn't work. Kicked tractor. Still, seen a lucas one (which I assume is decent quality) for £20, so can fix that.
What's more troubling is the relucance to turn over on the starter. I remade the battery leads and the starter switch to starter motor lead with the thickest wire available at my local agricultural supplier. No joy. Moved the earth from the dash to the oil filler cap. Nothing.
So if I work my way through the list of things it's not (leads, switch (works when shorted), earths, loom (new), generator (irrelevant (is it?)), I'm left with the battery and the starter motor. The battery was new from a guy who makes them for tractors. Outputs 6.4v. What I don;t know how to measure is the amps (or is it amp hours?) when starting. The manual says 75 amp hours, I guess I could be getting less than that?
Or the starter. All field tests in the manual been done and look ok, but could it need rebuilding? New bushes?
Is there anything else I'm missing? Tractor starts within seconds jumping it via a 12v battery, but it's not the way forward. Any further suggestions gratefully received!
Thanks, Matt
Thanks, Matt
