Urgent help needed on Head bolt specs
Anonymous-0
I am ready to re-install the head on a Farmall M, serial number FBK240103 and need the Torque in foot pounds and tightening sequence. Thanks in advance. You may reply here or send a message to [email protected] Please.
Some sequences are different, but generally like old says, plus alternate from side to side at the same time, rather than one complete side, then the other.
The pattern is designed to work any warp to the ends. Start in middle and work out in a circular pattern, like a spiral. You should end up at one corner.
