Used Cultivator?
I'm thinking about buying a IH 183 cultivator at a sale this weekend.
It looks like its been sitting outside a lot. I would like to ask what you think about: How hard will it be to fix it, make it work correctly? Theres not many moving parts, right? Just the main depth setting wheels and the rolling shields, I would have to make sure those move, and replace any parts, bearings, if needed. Probably replace the shovels, but I might have to do that with any used cultivator.
It looks somewhat rusty, with faded paint, but that doesn't matter, right?
I would buy it because I want to use it. I'm organic and doing old-fashioned cultivating, but only have 80 acres.
I'm guessing I could buy it for $400.
The alternative is one in better condition for $1,000 to 1,500
https://www.tractorhouse.com/listings/farm-equipment/for-sale/207449887/international-183
Your thoughts?
Thank you!
Bill
Looks alright to me. If the row units do not readily move up and down then remove pivot bolts followed by cleaning then lubrication. Teeth look like they have some wear left. Unless the dull look bothers you buy it.
It looks good to me! You'll like the rolling shields. Most of those cultivators had bushings in the parallel arms that could be replaced when it gets too much side play. Where are you located? I'm in NW Illinois if you don't get it bought, I have a 4 row Noble rear mount cultivator that I'd like to get rid of. Chris
Rolling shields look to being working condition & Danish style tines on the rear look to be in good working condition.
I have run a model 183 for years. They do a good job. Possibly the only problem you might find with a used one is the gang depth control wheel bearings may need replaced. A major upgrade that I always wanted to do to mine is to fix the parallel linkage like what was on the model 1820's. That would eliminate the gang floating from side to side with the bigger knuckles.
I hate being the lone nay-sayer here but I do organic farming for the neighbor. I started out with an S tine cultivator and found out real soon that does not work for organics. I sold mine and got a 183 with the vibra-shanks. S-tines can to easily flex around thistles and any weed that gets a stem as big as a pencil. Trust me on this one, you do not want s-tines.
That was what I was going to say if it has been used a lot the linkage will float from side to side or wobble. Pins get wore in the holes, however that one looks pretty good.
jm,
As a kid, I remember my dad cultivating the corn when it was hot and dry.
Before irrigation, my dad said that cultivating loosened the dirt and lose dirt didn't dry out as fast, keeping moisture in hard backed ground below the loose dirt.
I can't recall the last time I saw any farmer in my hood using a cultivator.
Can't recall the last time I saw a farmer using a plow either.
Same here. We had one much like that. It was a Brillion. Our ground gets hard, and that darn thing wouldn't dig. Dad's old four row front mount JD would dig. Enough that you could work the 2510.
