Farmallhal
I bought a used NH 273 a couple of months ago and did everything I could think of to get it ready for it's first outing here on our Missouri farm. Obtained an owners manual and dove into it like I was taking my first drivers license test years ago. Learned a lot from it along with a visit to my NH dealer for his input. Had a neighbor who has been around balers his whole life (he has a NH 273 also) walk me through the whole thing as we greased it up and checked everything out. Learned a couple of things quite quickly. The right side wouldn't tie and we quickly traced that down to the old twine which was left in the twine box and through the knotters. We started with new sisal twine in the twine box but left the old to drag the new through the needles and knotters. That was a mistake as the old rotten falling apart stuff got all plugged up in the right knotter. Had to dig and clean that all out of the hooks or fingers part of the knotter. The same knotter had some surface rust which we had to remove with some fine emery paper to polish them and to remove the rust which wouldn't let the twine off after typing. The left knotter never missed a single bale all afternoon. Next getting the tension set properly and getting the bale lenght set for normal bales. It must have been set up for baling Halloween thing bales which were very short. That helped as we got a lot of ties while we worked on the knotter typing problems. The only other real problem was one of the forks which moves the hay from behind the pick-up into the bale chamber was rotated some what and needed reset or adjusted correctly as we could hear a little banging noise when it moved all the way to the right. The pick-up slip clutch was an early issue but that seemed to work itself out as we found the right size windrows and feed rate it could handle. Didn't adjust anything there yet and the rest of the afternoon was uneventful. We put 395 bales through it and the last 300 or more were done without a single bale not being tied correctly. I think this thing is good to go for the rest of the hay season and don't expect anymore issues from this point on for now. I will coat the knotter parts with a rust preventative for storage after finishing the hay for this year. Also will get everything out of the bale chamber and put something in there for rust prevention. The chamber was without rust when I purchased it and intend to keep it that way. Thought I should share the experience as I had a lot apprehension going to the field with it the first time. I did have a couple of other balers I could fall back on if I had needed too here in the neighborhood. It probably took an hour or so to work out the issues I pointed out. That tool kit I bought to keep in the baler tool box paid for itself yesterday along with the shear pins I had for the baler when a large stick got into a windrow and in the baler, Hal.
