Valve spring question ??
drsportster
I have a spring with a 1 7/16 " diameter The valve spring retainer is 1 3/8 .The spring would slightly stick out from under the retainer . So run it or get a bigger retainer? What do the tailers say ?
What is the inside diameter of the spring or the wire diameter of the spring?
It would be the wrong spring for the engine. I would think the spring pressure could be wrong would affect how the spring would function. Too weak and the valve would leak or too strong and it would add additional wear on the camshaft.
Wrong spring or wrong retainer, they should match. I agree with Stephan. If the spring and retainer do not match, it can put unequal pressure on the valve stem.
I am sure Isky will have the correct retainers if they sold you the springs. O.D. of the retainer will be smaller than the spring O.D. That is how it is supposed to be!! Like I said the fit of the ID which usually has two steps is the part that has to fit correctly.
