Valve Stems leaking Calcium Cloride
We have a 350 Utility with loaded rears. I use it to drag a lot of logs for firewood. Lately the tires will develope slow leaks, then when I fill them the valve stem will leak water out of the stem. I have the stem at the very top of the tire. Is there any trick to avoiding this problem? I am very careful to not run over sharp stick etc, but I still generate leaks. I am almost starting to wonder if maybe when I pull hard I am slipping the tire on the rim which might pull the valve stem, causing it to leak??
Try putting in new tire valves as they get eat up inside and don't seal good. Even the tube part can get eat up and not seal. I had the tubes changed in the 4020 because of this.
Change the cores periodically. In spite of the fact that they"re sold as CH3 cores, many aren"t very resistant to corrosion. Replacing cores has become a part of my wintertime service routine. Saves a leaky tire in busy season. If you were slipping a tire and cutting the stem, you"d have more than a slow leak.
I had been wondering this too, as I had one that was installed and leaked from when the tire guy did the job. New tire, rim and tube, he said it would stop, nope, it leaked and where it leaked around the valve hole in the rim, the diameter of the hole corroded and became sharp, eventually the whole valve stem shot right out of the tube, was checking it, and glad I did, had it happened in the field away from the garage, would have made the job more difficult.
I've often wondered what happens if a CACL2 filled tube in a tractor tire leaked, if the tube chafed or somehow got an internal leak,would the fluid get in between the tube and rim, would the tire lose pressure or would actual tire bead hold tight. Concern obviously is that corrosive fluid getting to the rim always wondered how you would know or if an internal leak is possible.
Everytime I adjusted or topped off pressure in my loaded tires, the fluid shoots out, just have to be quick and rinse down the area after. You may want to get those repaired, only seems to get worse, I had this leak for 5 years and the valve finally popped out about 6 weeks ago.
Never took a tractor tire apart before, broke the bead, used a less than desirable pair of spoons I got at TSC, not even a matched pair, preference is for the drop center type, used the down pressure on loader to break the bead, mis matched spoons to remove the tire which was the most difficult aspect of it, have to be careful not to damage the bead tip, pry up a little at a time and use tire lube or similar to make it slippery. I repaired the rim, plugged the old hole by welding and grinding the inside smooth, then wire wheeled it heavily, painted the affected area with zinc rich galv spray. I followed the adavice of people here, also inflated the tube 1x, then let the air out, re-inflated, just had no time to re-load the tire, there is a real inexpensive valve for this, you can use with a garden hose, napa sells a pump you can power with an electric drill, not goint to be fast, but will cost less than a tire service call. I've since done some brush hogging and towed some heavy logs, funny that side is the one that slips first now, also have to remember to be careful until it is re-loaded, one side being heavier now.
I forget what the total bill was , but where I'm at there is a tire guy who makes service calls really reasonable. I think maybe $50 service call plus the tubes were like $100 for the pair then he cleaned up and primed the rims by the stem holes and I think a fluid pump in and out charge that was reasonable.
Only way to get rid of the problem, is to get rid of the problem.
That means running dry tires with cast iron weights.
Nest best solution would be running the tires no more than 2/3 full of a non salt water solution. A valve stem will never 100% seal salt water in.
Another problem is some joker filled your tires way too full of ballast. There is insufficient air space to offer some cushion.
The idea of pneumatic tires is that they are full of air and can flex. Filling a tire right full of ballast Makes it little better than steel wheel with rubber tread, plus it can leak.
Tires are too full. When checking pressure with the valve stems at 12 o'clock. There should not be any fluid at the valve.
