Steve Wein
I managed to damage the #4 con-rod bearing and the crank (my own fault - low on oil and tilted "downhill" in the Bobcat). The bearing didn't spin, but it overheated and badly scuffed the crankshaft journal pin.
Now, I need to remove the crank for a regrind and have a few questions for anyone who"s been inside this engine before. Trying to limit my work to what's needed...
1. Can the crankshaft be removed without pulling the cylinder heads and removing the pistons/con rod assemblies?
2. Does the oil pump have to be removed to remove the crankshaft?
3. Does the crankshaft helical gear on the flywheel end need to be removed in order to remove crankshaft from block? If so, how is it removed?
4. Are there any other items that MUST be removed to get the crank out?
5. How to remove/inspect/test oil jet nozzles?
Thanks for the advice and help.
Steve W
Steve W
