Vibration problem
Anonymous-0
I am the new owner of a 1939 JD model A, Its running quite well but a few things that i find odd are that if I have it in neutral and put the throttle all the way up the machine starts vibrating. Is that normal? when its moving there is no vibration. and if i have it in nuetral and put the throttle all the way down i hear the gears moving inside the crank. is that normal? any advice would be much appreciated, im sure its nothing but i just want to be safe. thanks in advance
ran a "a" for years when much younger but i dont recall them doing that.I think I would make sure the flywheel was not loose for starters,then check the clutch ,sounds to me just guessing somethings loose on crankshaft,but i haven't been on a "a" in nearly thirty years,so go from there.LOL
Both the flywheel and the clutch driving disc are TIMED to the crankshaft, if one or both is put on wrong it'll vibrate.
You may wanna insure the clutch drive disk is on the correct crankshaft spline, if not ITS VIBRATION CITY. While BOTH the flywheel and clutch drive disk must be on the correct spline, the clutch is removed more often then the flywheel and theres more chance its incorrect then the flywheel. If they are in time, the heavy side offsets on each are exactly 180 opposite from each other.
You may wanna check the torque n tightness of the 2 big rear flywheel nuts also.
John T
