W-6 transmission
mikey c
i just bought a W6, it drives fine but the transmission whines a bit more than i think it should. also, shifting lever has a little too much resistance when changing gears or when moving side to side in neutral. someone told me all this is common on these machines, is this true? any other idea?
I would suggest changing the oil in it first before you tear it apart. Maybe try adding some of the Lucas oil stabilizer as well. I have a W-6, nice looking tractors.
Charles
I would guess the ring gear and pinion are not set correctly or a bad pinion bearing Could be a gear was changed and not mating with the old one.Does it whine in all gears or just fifth
Hi chuck, its kirk,
I need pics of the hyd system on my 6,
And I dont have anything that shows that system the way it goes on our tractors chuck,
How is evertything down in your neck of the woods,
Hope things are ok, and hope your having fun with the tractor with MY WEIGHTS ON IT AFTER IT WAS SUCH A PAIN TO GET THEM OFF ARGHHHH HAHAHAHA thery look better on yours than mine anyway,
get back to me if you want ok chuck
take er easy ok,
kirk,
