on the grill it will have the small square ihc emblem instead of mccormick. it will have disc brakes and seal beam lights, as did the last w4's in the serial # range at end of 34,000 units. "approx" 3500 super's built the serial # plate will also have an s for super along with the low #. made only in 53 and 54.
(quoted from post at 06:37:35 03/11/13) on the grill it will have the small square ihc emblem instead of mccormick. it will have disc brakes and seal beam lights, as did the last w4's in the serial # range at end of 34,000 units. "approx" 3500 super's built the serial # plate will also have an s for super along with the low #. made only in 53 and 54.
Hydraulics?
IH equiped some W-4 tractors with the engine driven hydraulics starting somewhere around early 1951. Some information shows some 0-4 were equiped before that.
Different gears,different brakes,different lights,bigger engine (C-164 vs. C-152),larger air cleaner carbuetor outlet and air pipe for some things-
(quoted from post at 17:40:59 03/11/13) IH equiped some W-4 tractors with the engine driven hydraulics starting somewhere around early 1951. Some information shows some 0-4 were equiped before that.
That is about the same time frame as the 9s. IIRC they were the later half of '50.
