Walker floor jack info needed
bweb
I just bought a Walker two ton floor jack. It's a model 882. It is the one about four foot long. Can anyone tell me how to add oil to it? On
the cylinder there is a hex head bolt and then behind it are two slot headed screws. A large one and then a smaller one. There was a label on
it explaining the procedure but it is torn and missing the info. Thanks
The fill is almost always somewhere in the barrel of the cylinder, on the top with the jack sitting upright. It's usually a rubber plug.
Fill it, give it a few strokes to purge the pump, let it down before putting the plug back in. It will likely overflow. Then jack it back up enough to get the plug in. That will be the full level.
