Wanted 656 Utility Gas Engine
We are needing a good international 656 utility engine, mine is cracked block and not worth repairing, hoping to find a complete engine or good short block. Please Let us know if you have something or know where to find one, some of old international small combines used these engines possibly.Thanks
Any of the 6 cylinder gas engines will FIT , but you will have to use some pieces and part to make a row crop or combine engine work . Now as to finding a GOOD ONE that may take some doing due to the fact they all have had extensive field testing and been run hard and put away wet.
Bates is a few miles away from you in Bourbon. Assume you've tried them?
There are varying degrees of cracked blocks, some of the pinning systems can repair things you wouldn't believe. Discription and pics of cracks?
Your post made me curiuos about the pinning process so I watched a video. How effective is this repair and how wide of a crack can be realistically repaired ? I assume the answer to both depends on location somewhat ?
Thanks for your knowledge on these engines will check into it.
combines IH 403 and 615.. FYI, combine engines did not have sleeves, tractor engines did. I believe the front gear cover needs to be swapped onto the engine for side frame mount bolts.
Thanks, You definitely know what I should check into to make sure how much would have to be done to swap front cover. Thanks Again
I have a local mechanic that tore it down and found crack, he said it can be welded and put sleeve in then as I understand put a standard sleeve back in , only problem is $5-$6000 for all welding and repair and valve job and hope crank is ok may need ground, so I paid $5500 at a 4H auction then a few hours after got home found it was leaking antifreeze into #3 cyl. so if I put another 5-$6000 into it is going to be pretty expensive, may have to put clutch in while engine out, torque seemed to be ok, but will have to check it out also, it is a nice little tractor, so am going to have to decide whether to proceed or sell for parts tractor, has a nice loader in it also. Thanks to all who responded.
