Water in oil
550Doug
Location
Southern Ontario
My power steering fluid is milky as is the oil in my loader resevoir. Is there an easy way to determine the amount of water in the oil or is just the milkiness enough to say that the fluids should be changed? The tractor does get some rain (when not tarped) but also much comes from condensation. Any suggestions???
If the oil is milky, then you have about 10% or more water in your oil. Change it as soon as possible. You are probably getting rain water into your oil. Good luck.
