waterless hand cleaner
Dirty hands
What kind of water less hand cleaner do you all use? I am looking for some that you can wipe clean with rag or paper towel that will not leave greasy feeling on hands
. I used to use waterless foam hand cleaner before they stopped making it any suggestions would be good thanks
If you use the invisible glove you won't need anything but normal soap and the grease will glide right off. It is usually in the auto parts right next to the hand cleaner. I use the orange bars of soap with pumice. It's like Lava only sold in the parts store. I do have the one gallon pump bottle of orange cleaner in the basement if I forget to invisible glove coat.
I also used the foam hand soap and then they quit making it. The stuff I used was made by a place that makes dish washing soap. I kept one of the bottles and now I add 1/8 to 1/4 soap in this bottle and add water and shake. It smells the same as the foam stuff did and cleans just the same. Dawn soap works great in it. Much cheaper than hand cleaner you buy
Hey doc!
I used to use the invisible glove when I worked in a plant that mixed rubber. Carbon black is the worst but with that product it would wash right off.
If I might ask what parts store? We have azone and advance nearby.
Brad
The best i have found. [Auto Zone store] Dang i can't think of the name right now. It's orange. You can buy it with grit in it or smooth. It'. the best stuff i have ever use, What's funny is that i have been useing it at least 10yrs.Getting old ain't fun
I use Go Joe but it does leave some of the grit. A second clean paper towel clears it mostly but a water rinse is best.
Go Jo and Fast Orange are two citrus based cleaners that work well for me. The optional grit works well but can sometimes be tough to remove. Follow them with an alcohol based hand sanitized to take off the last greasy feeling. All three travel well in a pickup or toolbox.
The sanitizer will sting in any cuts or open skin, dry out your skin and chill as it evaporates, so I often skip that step in cold weather until I get in the house. I mostly use the sanitizer in warm weather or at the end of the day.
A coffee can half full of ATF (Automatic Transmission Fluid) is also a good hand cleaner for really greasy hands. It leaves an oily film, so use someting else to clean off the ATF.
Don't remember the name of it but they were orange hand wipes in a container. Worked really good. I need to get me a container of them.
D&L hand cleaner. Been using it for 40 years. Works great. But, never use it while your hands are wet or it won"t work nearly as well.
Pete
(quoted from post at 22:53:56 10/20/13) A coffee can half full of ATF (Automatic Transmission Fluid) is also a good hand cleaner for really greasy hands. It leaves an oily film, so use someting else to clean off the ATF.
Yeah but with todays cost of ATF!
I think it is a two store operation Mehle Auto Parts in Pearl River NY.They still have a machine shop although I have never used them.
Been doing mechanic work all my life and I've always had good luck with the smooth Fast Orange. Granted the kind with pumice works a little better at scrubbing stuff off, but if your in in the field, with no water to rinse off with, the smooth works much better.
I use Goop and It removes a lot of things off hands and clothes. It is geat for getting grease out of jeans.
New ATF never occured to me, I always have some used ATF to use in the can. Yes, new ATF would be expensive.
I like Joe's handcleaner. It can be used without water, but I like to rinse it off anyway. It doesn't smell like oranges or some kind of mineral spirits, more like bananas(?). I think it has lanolin and it doesn't chap my hands later. Works really well without a lot of scrubbing.
