David Farr
I had the coupling pin come out and sheared off I put in a new pin. it fired and ran 10 sec. it wont start again. I timed it by book no start. could something else have broken?I still get fire at plugs.
JMS, I had that thought as well. But why did it run at all after he started it? I wonder if the pin fell out again or sheared again.
Yup. Easy try- reset plug wires one hole forward on mag, try again...again, etc. Normally, top left on mag is #1, but doesn't have to be, as long as fire goes to the right plug at the right time.
Problem solved.Timing marks are not correct.I set #1
to top dead center and impulse coupling to snap at top dead center and at #1 Plug.Started and runs fine
Thanks for all your input.
